DC Jack and Gorva
Pasquada
Hey 👋🏻 all! Newbie here.
I’m about to install the pcb. But am a little vexed about the wiring and clear instructions on +/- soldering to which lugs on DC Jack as well as the Gorva footswitch. Eg on Gorva is there a specific way up down etc? On DC Jack which is + and -? Thanks. Feeling dumb. Any help please ?
@Pasquada
It's not just Gørva, all 3PDTs are oriented/work/numbered that way.
Same if it's a 3PDT Toggle, but note how the bat points depending on which row the common-lugs in the centre are connected;
in this diagram you can see better how each vertical "pole" is delineated with the colour-coding:
EDIT: PS: Sometimes you'll see the poles labelled as well — poles with numbers gets confusing since lugs are numbered,
IMO poles should be labelled "A, B, C" left to right.
You can extrapolate this "system" to DPDT switches
A . B
1 . 4
2 . 5
3 . 6
or 4PDT...
That's all for on-on switches.
Things get a little more complicated when talking about on-on-on switches, but those don't come in stomper-versions.
