Magnetron Delay Issue
brightlight
I built a Magnetron and was testing it a bit. It works 100% fine at all times when turned on, the issue is when it's off. After a few minutes of being off the signal fades out until it's gone completely. Turning the pedal on instantly fixes the problem for a few minutes and then it happens again. Any idea what these symptoms indicate?
