anevilspar7an
- Build Rating
- 5.00 star(s)
Just finished this up last week. I apparently had this board half finished from over 3 years ago since I have the old 50V Wima 1uF caps in it and a genuine THAT4103 IC. I did the mods that are floating around here to add Range and Shift controls to change how the gate does it's thing. I put the Range shift outside and labeled it Soft Up/Hard Down, added a ground lift to the Key In jack. I am probably going to replace those 100nF caps with Wima brand to match the others and swap the 560nF with an MLCC since the Kemet is pretty big.
