Hot Cake ~it's something~
falco_femoralis
This year I've been doing mainly outdoor projects - making a new workbench and storage setup in the garage, car projects, cutting up a drum kit. Today I needed to clean up out there so I could make room for phase 2 of the new storage setup, but I took one step outside and about faced right back in the house. I took refuge in the basement, far away from the oppressive heat.
This was my fourth pedal I tried to build today. The first needed a short bat on/on SPDT switch to complete, the second needed a C500k pot, the third needed a damn 9mm B500k pot instead of the B100k I ordered, and but this one actually came together! After this I greedily tried for another but it needs dumb pot values like C150k. I thought I had the others in stock but it's more difficult to stock up on pots than resistors and caps.
This was a standard top jack 1590b build. I used a footswitch daughterboard with LED mount and brightness control, and I used one ground wire for the two audio jacks. The silicone insulated wire I like to use makes it easy to strip the wire in the middle of its length. I'm trying out a new indicator light bezel. I looked all over for a washer to use as a trim ring but couldn't find one with a 9/16" inner diameter and 3/4" outer.
Gut shot first. I don't know why the daughterboard isn't square to the footswitch, but I tried making up for it with the trim pot 🤪 I'm trying out a full size nut for the power jack. The idea is there is more thread engagement vs the thin nuts they come with. The size is an M8 x 1.0 and it's a bitch to find them in the hardware store
My inspo for this was "something whitish like the original but also red because I like red"
Here's a bonus shot of some stuff patiently awaiting a tayda order. I want to complete these and build momentum before moving on to the rest of the stock pile
Given that this is one of the OG boutique pedal circuits I wanted to give it a thorough testing with both my stat and SG. I discovered that it's not so much a baseline overdrive pedal as one you would use as a boost to thicken your tone while taking a solo. It pairs nicely with other light overdrive pedals. It's really nice after a Tchula, but also sounds great after my Lovepedal Blackface Deluxe. I tried it after a TS with my Strat, but I have the TS set up to be a mid boost kinda thing as well and having both was somewhat redundant. It's also just about the only drive pedal I have that sounds good with a compressor. It sounded best to me with the vol and tone at noon and the gain from 12 to 2 o'clock.
I really like the range of colours in a such a simple looking wipe. Where do you live that it's so hot right now? Obviously northern Hemisphere! It's pleasantly frigid where I am right now. I took a walk today in the rain (I love walking in the rain). It was a slow, short walk and the temp was maybe 12-15C and it was around a lake. Beautiful!
I don't know about where you are but in my town we have a place which specialises purely in fasteners. They have everything! I found it when renovating motorbikes. Good fasteners can make most jobs easier.
Looks great! I like the effect you get with your enclosure colors. I’m assuming simple acrylics just smeared/wiped across aesthetically pleasingly (I could be stupid too. Oh wait, I are dumb).
Hoping to have my Hotcake up by the end of the summer as well. Thanks for the feedback on the circuit.
I'm in the northeast part of the United States. We get 6 months of freezing temps and then 5 months of hot humidity with two weeks of nice weather on each side. I wish we had a store like that, but everything is big box these days.
Yup they are acrylics in various colors brushed onto each enclosure. I'm not good at drawing but I wanted something more interesting to me than spray paint so I started doing this. They have a polyurethane clear coat on top.
I absolutely love the coloring you are getting on the enclosures! What kind of paint are you using to get that effect?
I really want to try this out, it looks cool as hell.
I just went to the art store and bought a few tubes of Liquitex acrylic paint. I spent some time learning about color theory to figure out what shades might work well with each other. Every color leans toward another and that's how you can tell whether they will blend nicely. For example there are two versions of a blue color called Ultramarine Blue - one has a red undertone, and the other is green. I always use the red one because it will blend nicely with purples I like, whereas the green version when blended with those colors will turn out muted and dull.
Every so often I'll buy another color to try out. Much of it is experimentation and if I don't like the outcome I'll wash it off and try something else. Sometimes I have to repaint the enclosure entirely if it just doesn't turn out good enough. I have a few I've tried to paint like 4 times when chasing a certain theme. Those are often the worst ones. What works better is just trying stuff and stumbling across something by accident. It's like another facet of this hobby to explore.
