evil.audio
Hey everyone!
I’m working on a dream fuzz (ehx big muff op amp clone)
I’m pretty much out of ideas of what’s wrong with this thing. The LED turns on and It outputs sound however the signal is extremely low, very muffled, and very bass heavy. Nothing close to resembling a big muff! Bypass mode works fine.
So far I’ve tried:
So far I’ve tried:
- Double checking every component value (hence the white paint pen everywhere)
- Reflow soldering every component
- Replacing the ICs
- Replacing the 3PDT switch
- Rewiring everything coming off the board
- Measuring vcc pin on each IC which was about 8.6v-8.7v
- Jamming cardboard and Kapton tape between the pots and the board to prevent shorts
- voltage measured across the ground and SW solder pads on the bottom of the pcb was 7.5v which I thought was strange.
- the tan resistors were from an old Amazon assortment kit I had laying around. Being carbon film maybe the tolerances are way off although I measured a few and they were very close to their listed values.
- I might build an audio probe and trace the signal path?
