Carmine suddenly very loud
Bret608
I boxed this last week and tested it out; sounded great (see build report over in that area of the forum). Tonight is the second time I played it and for some reason it's extremely loud, at least intermittently. With the volume and gain all the way down, there is still sound, like a clean-ish boost. Turn the gain up and its pretty bruising! I also noticed some ground-y sounds when turning the pots. I'm suspecting a dodgy joint on one of the diodes. Any other trees to bark up would be most welcome!
Clippers would be my guess as well.
If you used a Elcap for C5, it could be leaking DC on the tone and output pot. That would potentially add dc offset to the clippers as well
Thank you, I will check that out. I don't think I have a film cap in the ballpark at the moment but would drop one in my next order or grab one at work. A couple of other things to note, which I'm now remembering from when I tested the board outside of the box (and which, at the time, I chalked up to my testing box getting dodgy): 1) I wasn't getting sound at first; it was like things had to charge up or something; 2) I was getting crackle and even some pops/ground-type noise when I moved the pots?
Okay, so I check leg 1 on the tone pot with my DMM. I'm getting 0 up to 0.7mv at most. Let me know if that sheds any light. It does seem like an electro in the signal path may have been a less than optimal choice if film was an option, unless I'm missing something.
The picture may not be a huge value-add, true; I've already checked resistor values, orientation of anything with polarity, that the diodes still have the same fv they did before soldering, etc. Thank you to anyone willing to take a look, though!
That's the shotgun approach. I'd rather know where the problem is before I fix it. Just my $0.02 worth.
Im not one to shout reflow from the get-go but I see properly flown solder on 3 axial joints. Don't need to see the back. Visual inspection result is most of the joints are sus and OPs iron is probably too cold.
Starting to suspect my iron a bit honestly, and my eyes can't get too far without magnification (which I definitely havent done yet). In other words, I'll be trying all suggestions!
I’ve gotten to the point where if I don’t see a little solder flow on the component side of the board I reflow until I do. Is it right? Maybe not…but several of my duds were from bad soldering. I also upped my temp and got some magnifying glasses so I could se what the hell I was doing better. I’d listen to Chuck before listening to me though. 😂
That sounds like good advice too! This is pretty much the weirdest bug I've had in fifteen years of pedal building though. The volume pot is doing nothing and the gain is like a super-loud master volume, lol. Hopefully I can get it back to sounding like it did this past weekend.
