Carmine suddenly very loud
Bret608
I boxed this last week and tested it out; sounded great (see build report over in that area of the forum). Tonight is the second time I played it and for some reason it's extremely loud, at least intermittently. With the volume and gain all the way down, there is still sound, like a clean-ish boost. Turn the gain up and its pretty bruising! I also noticed some ground-y sounds when turning the pots. I'm suspecting a dodgy joint on one of the diodes. Any other trees to bark up would be most welcome!
Thank you, I will check that out. I don't think I have a film cap in the ballpark at the moment but would drop one in my next order or grab one at work. A couple of other things to note, which I'm now remembering from when I tested the board outside of the box (and which, at the time, I chalked up to my testing box getting dodgy): 1) I wasn't getting sound at first; it was like things had to charge up or something; 2) I was getting crackle and even some pops/ground-type noise when I moved the pots?
Okay, so I check leg 1 on the tone pot with my DMM. I'm getting 0 up to 0.7mv at most. Let me know if that sheds any light. It does seem like an electro in the signal path may have been a less than optimal choice if film was an option, unless I'm missing something.
The picture may not be a huge value-add, true; I've already checked resistor values, orientation of anything with polarity, that the diodes still have the same fv they did before soldering, etc. Thank you to anyone willing to take a look, though!
I would go ahead and reflow.
You have very little solder coming through the through holes. Should see if flow at least to the point of flush with the other side of the PCB.
