This Week on the Breadboard: The Golden F**k
Well I've been experimenting with this circuit. It's a great circuit stock of course. But through my amp it's possibly a bit more compressed than I'd like and I barely use the Normal channel at all - it's usually only just on, and anywhere above 9.00 it just adds a rumble and takes over. On its own it is actually a lot darker than the normal channel on any 4-hole Marshall I have played. I've built quite a few JTM45 and 1987 style Marshall amps and invariably mod the Normal channel to make it more useful. In fact what I often do is make it more like the Bright channel, just keeping it enough different to justify having two channels. This makes sense when you look at the history of Marshalls. They were built to the Fender 5F6-a Bassman schematic after all.
So at first I tried doing what I do to the amps but to the pedal. I reduced the 100µF C3 to 47, then 22, then 1µF - and that's still plenty bassy. I often add a 470pF bright cap at the mixers to the Normal channel too - that's like C8 on the Golden Falk only I would put another in parallel with R6 in the GF. But I wondered why I would bother - the channels are already very similar. So I tried removing the Normal channel altogether and adding a Bass pot to the Bright channel at C4. After all, that section is where the two channels differ in where the low end cuts off.
So I kept the 470nF cap at C4 of the Bright channel and tried a few different cap values for the lower extent of the bass and settled on 22µF with a B10K Bass pot. This saves a fair few parts and I actually like the sound better. And for some reason as a bonus it appears to have reduced the compression somehow - maybe having one less transistor pushing the clipping section has had an effect? I don't know but I like the sound. This is where I ended up:
I'm sure most of you will still prefer the stock Golden Falk but I thought this might interest some of you. It really works for me - It actually sounds and feels more like the old Marshalls I have played and the amps I like to make. The stock GF is kinda more hot-rodded Marshall; more Van Halen or Slash. Mine is more Malcolm Young. :)
Thanks for writing this up, Chuck. The Golden Falk is a great Marshallesque pedal! I hope I haven't hi-jacked your thread - let me know if I have.
Can I ask a more basic question about this circuit. I read the Fetzer Valve Revisited article on runoffgroove.com, and the first gain stage looks familiar. For the gain stage of both this and the Viceroy we have the mu-amp. What is the reason for that? Does that allow pushing the distortion harder than a straight f.v.r. style of gain stage?
BTW I had a C10K for Bass originally but it made the low end come on too quickly. I also tried a 100nF cap at C3 which gives a wider range obviously but figured that the original has 220nF as the effective lowest level for bass, so...
(edit) 470nF!
The Mu Amp does two beneficial things for us, compared to a simple one-transistor amplification stage.
1. More Gain! *
2. Nearly symmetric clipping.
* HamishR increased R6 in his Mongrel pedal to moderate the 2nd stage gain.
FWIW The specified drain voltages worked perfectly in my first build but in my second I found the sound was a little squeezed - maybe a bit too scooped. To me it sounded like the transistors were biased too high. Reducing the bias voltage a little brought the newer one to life. I assume it's owing to the variability of J201s? I didn't measure the source voltages. I just mention this in case anyone finds the sound not as amazing as expected. Just experiment with the bias, using the recommended voltages as a guide.
Not everyone has your discerning ear, my friend. If there is variability from build to build, it can be as much subjective as it is objective. I do appreciate the food analogy, though. Reminds me of lemon sorbet... a little squeezed, a little scooped. 😎
MMmmm .... Sorbet. Before we had aircon I used to make a lot of lemon sorbet to try to keep us cool in summer. I used an old recipe from my mum. I reduced the amount of sugar significantly and used more lemon juice. Sooo good.
The difference in sound was enough to make me think I must have done something wrong (still entirely possible!). It was enough that if this has been my first build of this circuit I would have dismissed it as just ok, not a great one. Fortunately a slight tweak and it's back to being a fantastic circuit.
Varying the drain resistor does more than affect the drain voltage. It also changes the output impedance and linearity. The difference between 15K and 20K may or may not be noticeable. The difference between 15K and 30K will be more pronounced.
It's never something straightforward, is it??
Thanks Chuck. I still don't understand half of what you say but the bits I have used have improved my pedals immeasurably.
I love reading through these threads because it always blows my mind how much knowledge people here have that I wish I could instantly learn lol.
So I have a Golden Falk PCB that I plan to start ordering some parts for. I've noticed a lot of the tweaking and modding in this thread was in regards to the 1987 high gain sounds. The JTM and 1959 Plexi modes of this pedal and lower gain sounds are what appeal to me and I doubt I will even use the 1987 mode at all.
I'm trying to make sense and track all of the mods discussed here regarding things like the choice of all J201's or having 2N5457's at Q3 and Q4, the different resistor and cap values....but I am struggling to make sense of the best direction I should go, or if I should even swap parts out at all.
If I primarily play a Stratocaster or Telecaster with single coils, plan to use this pedal for the JTM and 1959 edge-of-breakup and lower gain Marshall sounds you get out of a Strat neck pickup into an old Marshall, can anyone be so kind as to recommend any direct mods to the PCB build? @Chuck D. Bones @HamishR @temol
I plan to use this pedal as either in the FX Return of my Mesa Fillmore 50C to emulate a true Marshall preamp, or just in the front input of the clean channel set as a pedal platform.
Thanks as always!
Thanks as always!
As a heads up, I used to have a Fillmore 50 and this pedal sounded great into it with the two lower gain modes. I did not go the fx loop route but straight in front.
I would run fuzz/od into modulation and delay then into the golden falk into the fillmore. This way it was more like a preamp and tone shaper.
