Chuck D. Bones
Circuit Wizard
I tried 2N5457 for Q1 & Q2.  I had to raise the drain resistor by about 50% in both cases.  The gain was more than 2x the gain with J201.  Which is good if you want the extra gain and have low output pickups.  Or if you have high output pickups and aren't interested in playing clean.  250mVp-p on the input was enough to drive both channels into distortion, mostly 2nd harmonic.  Id was 245μA for Q1 and 86μA for Q2.
I tried a pair of 2N5457s & a pair of 2N5246s for Q3 & Q4. They both had about 1dB less gain than the J201s I had in there. Even though the 2N5457 & 2N5246 have higher transconductance than J201, they have a lower output impedance. In mu amps, output impedance matters.
I tried 2N5457 & 2N5246 in the output stage. With 2N5457, I had to reduce R14 to 330Ω to get the biasing right. The gain was 17dB higher than with the J201. This is good if we want more gain. With the 2N5246, I had to increase R14 to 2.2K to get the biasing right and ended up with 2dB less gain than the J201. Unless we want to add a bypass across R14 to bring the gain back up, the 2N5246 is not a good choice.
As Tomasz has demonstrated, we can use a variety of JFETs and get interesting results.
I'm leaving the MMFB201s in the board I already have assembled. When I build another one, I'll probably experiment with alternate FETs.
