UniCab build - bypass works, effect path very quiet, no knob changes anything
Soozay
Built a UniCab (3x TL072, board matches the current build doc and schematic). Bypass works fine and the LED lights, but when engaged I only get a very faint signal at the original tone. None of the six pots change anything I hear.
What I've checked:
- All three TL072s are oriented correctly, and supply and bias voltages at the op-amps measure correctly (8.8v and 4.4v where they should be)
- Pots are the correct values and tapers, mounted on the underside
- Footswitch wiring matches the build doc, and I/O and ground continuity all check out (continuity from the board's OUT pad to the output jack tip and GND to the jack sleeve both beep)
- R16 measures 9.92K, and OUT pad to ground measures 99.7K (R17)
- Audio probe: strong signal at IC1 pin 7 and IC2 pin 7, and on both legs of C15, but the OUT pad is faint
What doesn't add up: if the signal is strong at C15 and R16/R17 are correct, I'd expect a strong signal at the OUT pad. The faint sound also doesn't respond to any control, so it may be dry signal leaking through rather than the effect. Power: Any ideas where to look next? Happy to take more measurements or uncase and send pic of solder side.
Does the condition change with all of the opamps pulled out of their sockets?
No response from any of the knobs makes me wonder if it's a wiring/footswitch issue. Maybe a stray wire strand around the footswitch?
Either jack shorting to the enclosure / DC jack nut?
Yeah, I'm going to double-check the footswitch wiring. I don't think its's a jack short, as it's occurring when it's out of the case.
I've run continuity tests on the 3PDT wiring, but I may have just hit the wire ends...which of course I'd get continuity. Probably worth a second check.
Thx!
