ftumch
I built another Electrovibe and everything works but the LFO
With some troubleshooting I've figured out the the LFO ground plane is disconnected from the main ground. When powered up LFO ground sits roughly halfway between the 18V and 12V rails. I have continuity on the LFO and lamp grounds:
And continuity across everything else, but no continuity between them
I can't figure out where the grounds are supposed to meet:
Can anyone see what's going on?
(The scratches in the solder mask are from my multimeter probes while trying to figure out the problem, so they came later. They are surface deep)
I've reflowed a load of joints, no chagne
