125b Pedal Risers Anyone?
are you not using top mounted jacks? is the problem that you drilled the 1/4" jack holes too close to the bottom of the enclosure?
Now you've got me curious. Can you take a picture of one of yours with the pancake plugs in?
Has anyone solved for using PedalPCB 125b builds with pancake plugs on a flat board?
The 125b enclosure needs about 5-10mm of clearance added (minimum) to fit the stoutest pancake plug (Square Plug SP500).
In my case, I'm weighing between cutting individual risers for each 125b pedal on the board vs a long strip to accommodate them all in a line.
Others out there surely have run into this obstacle before.
You could try moving your in and out jack holes closer to the face of the pedal. There should be plenty of wiggle room. I use 1590b boxes with too mounted jacks for most of my builds which requires me to move the jacks closer to the face and I’ve had no issues
i currently have a temple audio board, and use a mix of cables. im phasing out pancake plugs because they dont fit through the routing holes in my board. but ive never heard of or had any issue with pedal height interfering with pancake cables. ive had flat wooden boards in the past and never had a problem then either.i think my board probably looks like anyone else's.
