2-in-1 Enclosure for Notakliché and Cobalt Drive--Tayda Drill Template
greypilgrim76
Hi All,
So I'm in the planning stages for my first 2-in-1 pedal, which will combine a Notakliché with a Cobalt Drive. I'm currently working on the Tayda drill template for putting them in a 1590XX enclosure. I took the template for each pedal and then basically did the math regarding distance between drill holes and edges of the enclosure. It was tricky, though, because the 1590XX and 125B have different X-Y axes for hole coordinates, and then each side of the 1590XX measures from different axis points. Anyway, I think I've got a roughed out template, but if anyone with more experience would want to take a look and see if I'm missing any obvious problems, I'd appreciate it.
A couple of notes: first, I moved the LED holes for each pedal to the bottom for symmetry. (Holes #10 and #11.) I know that'll put the Notakliché LED under the board, but I think there'll be room. Second, Hole #12 is for the direction switch.
Okay, here are the templates I used for my calculations:
And here's my current template for the combo pedal:
Any thoughts or warnings appreciated! :)
PS--I wasn't sure whether this best fit in "General Questions" or "Troubleshooting." If I chose poorly, please feel free to move it.
Hi All,
I couldn't get the link to pop up correct for me to your drill template..
I just looked it over quickly and it looks like you have it laid out really good. IMHO I think your good to go. The only real concern I have is if your jacks are going to hit your pots...
Cool, thanks for taking a look. As far as the drill holes for the jacks, I used the same measurements as the ones on the Parentheses Fuzz. That board doesn't take up as much space, so I adjusted the jack holes to match (I think) the distance from the bottom of the enclosure on the Notakliché, since that'll be the tighter side of the build. It was only about half a mm, but I think if I use open jacks, it'll hopefully work okay? Here's the updated template (in case anybody else decides to give this thing a shot at some point and doesn't want to start from scratch):
