megatrav Well-known member Jul 11, 2021 #1 Wondering if it's possible to do a 2-in-1 pedal wiring with one bypass switch and then a footswitch to choose between the 2 circuits?
JamieJ Well-known member Jul 11, 2021 #2 2-in-1 Pedal Wiring (AB) - PedalPCB Wiki wiki.pedalpcb.com This diagram is on the wiki
Barry Well-known member Jul 11, 2021 #3 I guess my initial response would be why? If you wire them in series you have the option of either or both
megatrav Well-known member Jul 11, 2021 #4 JamieJ said: 2-in-1 Pedal Wiring (AB) - PedalPCB Wiki wiki.pedalpcb.com This diagram is on the wiki Click to expand... Thanks! Now I just need to figure out how to do it with the simple relay bypass
megatrav Well-known member Jul 11, 2021 #5 Barry said: I guess my initial response would be why? If you wire them in series you have the option of either or both Click to expand... I am going to do a dual "preamp" pedal with a WIIO or RAH and a Dirty Little Secret. I wanted to set one as my clean-ish tone and the other as my crunch tone
Robert Reverse Engineer Jul 11, 2021 #6 I would be tempted to use the Intelligent Relay Bypass module for something like that.
