2sk208-Y vs 2sk208-R Low Tide
Looks like R is rated at 30mA-70mA
Not 30 mA to 70mA but 0.3mA to 0.7mA. This is one of the parameters that characterizes JFET transistors - Idss. And you cannot use it in relation to the current draw of the circuit.
Low Idss and Vp values put R version close to MMBFJ201. Most 2SK208R I've measured had very low spread of the Idss and Vp, lower than MMBFJ201.
This calls for the 2SK208-Y, but you can probably get away with a 2SK208-GR (higher Idss) - I also saw someone in another thread using the -GR variant. The -R is 2 Idss bins lower than the -Y, so I wouldn't recommend it. I'd use the J201.
Another option is the 2SK30ATM-Y, which has the same Vp & Idss, but a different pinout (so you'll have to rearrange them on the board). I used this and it works great.
I used a 2SK30A-GR (low end on the GR scale) also and it worked fine. You could also use a 2SK246-Y and it would work fine.
On the same quest, but did I read that right, that I can sub a J201 for the 2sk208-y?
