2sk208-Y vs 2sk208-R Low Tide
Looks like R is rated at 30mA-70mA
Not 30 mA to 70mA but 0.3mA to 0.7mA. This is one of the parameters that characterizes JFET transistors - Idss. And you cannot use it in relation to the current draw of the circuit.
Low Idss and Vp values put R version close to MMBFJ201. Most 2SK208R I've measured had very low spread of the Idss and Vp, lower than MMBFJ201.
I used a 2SK30A-GR (low end on the GR scale) also and it worked fine. You could also use a 2SK246-Y and it would work fine.
This calls for the 2SK208-Y, but you can probably get away with a 2SK208-GR (higher Idss) - I also saw someone in another thread using the -GR variant. The -R is 2 Idss bins lower than the -Y, so I wouldn't recommend it. I'd use the J201.
Another option is the 2SK30ATM-Y, which has the same Vp & Idss, but a different pinout (so you'll have to rearrange them on the board). I used this and it works great.
On the same quest, but did I read that right, that I can sub a J201 for the 2sk208-y?
I am trying to figure out the pinout od 2SK208-GR as I have 2 versions of adapters. I read the S and D are interchangeable, and yet I had an older build where it seemed to matter.
So I get to Toshiba datasheet from varous sources but cannot tell if the drawing is from above or below.
I checked the schematic and pcb to find which pins correspond to 1 2 and 3 in the schematic.
How to determine which is which?
Datasheet
Build doc
On first page of duild doc, the pcb, the pins are 3,2,1 left to right for Q1 with 2, 3, 1 top to bottom for its smd.
1 goes to the R4 in schematic and 2 down to R3.
