3AX31C Germanium gain
Ok so I made the RG Keen tester, I think based on the continuity test, when the switch is in the up position, the bottom two poles are connected? And in the down position, the top two poles are connected? I wired it so the 2m2 is connected to the top lug, and the middle lug is connected to the ground plane.
I used this guide. https://www.freestompboxes.org/viewtopic.php?t=9851 EDIT, the power and DMM meter connections are reversed compared to the guide due to NPN topology of the 3BX31C.
If I got everything right, one of the 3BX31C that showed up with no leakage reading on the TC-1 had a reading of:
2M2 floating 0.083v, and 2M2 connected 0.772v.
Which would mean 0.772 - 0.083v = 68.9 hFE, and ~ 30uA leakage?
I tested one of the PNPs (3AX31C) that I had tested on the TCR-1.
The TCR-1 tested a hFE of 64 and an Iceo of 66uA.
My Keen tester (assuming it worked) read a voltage of 0.075v with 2M2 floating and 0.566v with 2M2 connected to ground which would equate to a hFE of 49.1 and a leakage of <50uA. Which I think means the tester is working?
Hey folks. I built my first ever bread board circuit, an LPB-1 and tested the NPN 3BX31C. It biased up nicely, here's the oscope results,
1000khz 0.6v P-P signal input
1000khz 1.2v P-P signal input
Haven't measured the biasing resistor values yet, but seems like the low leakage readings were real. Pretty nifty lot given out of the 10 I got from AliExpress 6 of them have a Hfe over 65. No idea how it sounds yet.
I mean, I knew they weren't actual AC128s!
Color me curious. And color me unwilling to take other people's word for it.
Also, color me out a few bucks with a bunch of useless germs. Nbd.
I kinda am hoarding all the germs right now.
Did you ever do more testing on these? Do you think they are actually germanium?
I mean, either that or they soldered a resistor in parallel with the emitter and collector.
I'm not even convinced that these things are *transistors*, truth told.
The crazy thing to me is that enough people are buying these that it's worth manufacturing them in the first place?
Is the casing from a well known package type?
I mean, it's a TO-5.
Which, most of the time, that particular transistor tends to be in a TO-1. At least as far as I've seen.
Chinese transistors tend to be in different packages.
I dunno...I doubt these are new production. Mostly because I don't see anything with new production germanium transistors coming out of China.
Could be they bought up a bunch of QA rejects, gave me a good shine up and slapped a nonsensical label on em.
Shoot...I dunno what the deal with these is. It's a mystery.
I dunno, it looks like a TO-1 to me:
I’ve used both 3AX31 and 3BX31 transistors in multiple builds, and they definitely behave and sound like germanium transistors. They do need more sorting for dead or hissy transistors than western or Soviet devices, but the good ones are quite good.
(I have seen the shiny TO-5 looking devices listed on AliExpress as AC128 or some other incorrect western part number and share your skepticism about those.)
Whelp, I gave this specific variety a shot recently (3ax31c). Got 100 of em.
The quick and dirty tc-1 test is promising. Good gain, between 60-130 from what I've seen so far, under 300mA (though this is pretty often inaccurate on the TC-1).
We'll see how they do once I get my mega-tester built.
For what it's worth, this is my updated data on the Chinesiums
Decided not to get more AX's as I'm happy with my Ruskies in the PNP realm. the BXs test well though, have yet to listen to one in a circuit though.
Mega tester?
Its gonna be a multi-device tester using the RG keen method.
Basically...pop in four different devices. Power em up, let em stabilize. Test leakage on one, flip a switch to test gain. Remove, replace, let that one stabilize as you move on to the next device in the line.
Should make testing a bit faster.
