Robert
Reverse Engineer
Where are you folks getting your 9mm pots?
I ordered some from Tayda but the threaded collar isn't long enough to reach through the enclosure if a 1mm faceplate is used (and just barely fits with the washer and no faceplate).
I've seen builds that use them with faceplates, so I'm thinking there must be a supplier with a more adequate part?
