A genuine 1965 Princeton Reverb. Quite something to behold because it was so pristine. He had only just bought it so wanted me to check it out for safety and set up. It had a replacement stand-up PT for our 240V wall voltage but it was installed using the original screw holes and was actually a really neat job. Whoever replaced it knew what they were doing. The AC cord had also been replaced and although it wasn't strictly to code it was done well. The ground wire should have been longer and it was attached to a lug on the PT mount.
But the rest of the amp was PRISTINE. I should have taken photos! I have never seen an original Fender in such untouched, clean, perfect glory. I was amazed that the original caps all worked just fine. No sign of bulging or leaking gunge. Really low noise floor - way quieter than any PRRI I have heard. It had two different brand 6V6s in it but they were perfectly matched - the plate voltage was identical on each tube. Everything worked except that the reverb tank was a bit sproingy. The bias tremolo sounded lovely, the bass stayed nice and tight until the volume was well up. Surprising amount of clean headroom with my Strat which has fairly hot pickups.
Overall it was so much quieter, better sounding and tighter than every reissue I have heard it's crazy. My friend will be using it at a gig this weekend.
So the only thing we have done is to replace the stock ceramic speaker with a Celestion 10" Gold. It has made a huge difference - much louder, fatter and betterer. The stock speaker will be kept to sell with the amp if/when the time comes.
It was such a pleasure to see such a time capsule of an amp. BF Fenders are not really my thing but this one was so well built it was good to see. I love old amps, especially one as perfect as this.
