Good job, I think the original had some hiss too, from what I remember on tgp.
Good to know! I've got some lower noise op-amps coming. Maybe that will tone it down a bit. I can live with it, but I'd like to do better!I have an original, the hiss varies with the ratio setting on mine
Q1 & C26 would not cause that. I'm guessing a wrong component or two somewhere. According to some of the posts in Troubleshooting, Musikding has been known to kit incorrect parts. I have no personal experience with Musikding, I'm just going by other peoples' accounts. Make sure all of the Rs & Cs match the PedalPCB build docs.Hello everyone! I built this as a kit from Musikding, the included 470n C26 is a polyester capacitor and the J201 is a SMD component (don't remember the code) with an adaptor to be mounted as a regular transistor. Beside the noise slightly high, as many of you recalled, I confronted the pedal against an original Dude. The Abider as a distinct mid "honk" that isn't there in the Dude and it's a lot less transparent compared A/B, otherwise seems to be ok. Could be that those two components makes such a difference, it's just the way it is or I might have misplaced something? Thank you!!
Damn, why you gotta break it down like that, now I don’t even want to build mine, haha. Kidding though, thanks for the good info.Which segues nicely into...
The Dude is a Nobels ODR-1 with a few very minor component value changes and the SPECTRUM control hard-wired at noon, driving a Rockett 45 Caliber with the GAIN control hardwired to 8:00. This all could have been done with just two dual opamps because IC2.2 does nothing and IC3.2 is abandoned.![]()
