jpd
Hi all,
I’ve built 4 Abyss pedals in the past with no issues, but having a weird issue on my latest build that I can’t figure out.
When power is first applied, the LED blinks at rate as intended, but eventually after about a minute, it doesn’t go all the way dark, then eventually the LED just stays fully lit. I get phasing as expected, then I still get the boost from the level knob, but no phasing as the LED stays on. I’m assuming this has something to do with the LFO part of the circuit.
Ideas for things to look at? I pulled it from the enclosure to make sure something wasn’t shorting or grounding out, still does it out of the box. Wondering if anyone has test voltages on the TL074 pins I could check against. I tried swapping another TL074 with no joy.
Thanks!
Thanks!
