angelrulax
Can you upload a photograph of your build? Thank you.
I think you were probably asking this of BrainDrain, but here are a couple of pics from my recent build with the 2nd LED wired to show both status and rate. I wired pretty much according to the diagram I posted earlier. It's hard to see, but the blue wire coming from pin 8 of the 3PDT is going to the land where pin 3 of the Voice pot would normally go. The green wire from pin 9 of the 3PDT goes to the 3rd leg of the Voice pot, which is severed so it's not connected to the board. The cathode of the 2nd LED is connected to pin 7 of the 3PDT and the anode shares the connection with the green wire on pin 9 of the 3PDT.Can you upload a photograph of your build? Thank you.
So, I ended up using a 5mm LED for the rate/status LED. I originally had a 3mm in there and had an issue when I first fired up the pedal that took out both LEDs and the Voice pot. After reviewing all the sage wisdom of this forum (thanks guysHow much did the 2nd LED affect the Voice pot?
