ADHD oscillation
rstofferahn
Hi yall!
Pretty new to building and modding pedals. Ive done about 15 or so builds, modded about half of them.
So Ive got a question regarding the ADHD build I just finished.
I went and populated the board with the parts listed on the pcb (since there isn't a current build doc). Sounded good, but a bit bright and not much bottom end. Started with swapping out C4 (1nf) with a 10nf. Then I went and pulled C3 and added a on/on toggle to switch between the "stock" 100nf cap and a bigger 470nf cap just to see what would happen.
Sounds great, but I found that with the gain MAXED the pedal starts oscillating almost like a weird tremolo pedal, but back off on the gain just a bit and it stops. Its not necessarily a problem since I typically would never use that much gain on this pedal
My guess is the low end is overloading the TL072?
I pulled the TL072, put a socket and tried a TL082 and then a LM833n. Problem still persists.
Any ideas on what is causing it and any remedies? Obviously I can just lower the 470nf cap, but since Im still new to this...im more so just curious on what is causing this.
Thanks!
Easiest solution is just don't do that. :ROFLMAO:
I don't have the schematic in front of me but it's possible you are messing with the wrong caps.
lol yeah, I never max the gain on an ocd anyways.
I got the idea from the “bandwith” on the eqd dunes/palisades (oasis/stockade), increasing the low end into the drive section…or at least that’s how I understand it lol
