I recently built the AionFX Amethyst (Boss DM-2); see my build report.
I touched on a bit of this in the build report, but basically: I found the bias trimpot to be very sensitive, so replaced it with a multi-turn trimpot. I initially biased/calibrated by ear, as I didn't have an oscilloscope. I thought I got it to a pretty good place. I then used the front controls to try and set it similarly to how I have my Boss DM-2w, a fairly quick slapback with only two or three repeats. It sounded pretty good with light strumming. But then I went back and forth between it and the DM-2w, and realized there was fairly noticeable distortion on the repeats.
I assumed my by-ear calibration was to blame, so I ordered a cheap oscilloscope (DSO154Pro). I received the scope last night, and went through the calibration process again. I was a bit impressed with my by-ear calibration, as it was surprisingly close to optimal. I tweaked it a bit anyway. I was also able to do the clock cancellation adjustment, as that requires a scope (previously I just set the trimpot to noon). Though that trimmer only required a minute adjustment.
After all that, I gave it another test - and the distorted repeats are still there. If I play really lightly, I don't notice, so it seems to maybe be a headroom issue?
I used the (substantially cheaper) V3205/V3102 chips and am running at 9v.
First thing I plan to do is repeat the calibration process again. But if that doesn't work, I'm wondering what the next steps would be? The pedal fundamentally works, so I don't think I made any egregious error. From my very rudimentary understanding of BBD delays, the compander and filtering are crucial. Are there particular components in this part of the circuit that, if wrong or out-of-spec would be more likely to cause distorted repeats? Also, the feedback control seems too sensitive to me - it will go into self-oscillation much sooner than my DM-2w (moreso than I would expect as a result of component tolerances).
Hoping some other folks out there have some experience addressing this kind of problem on DIY BBD delays.
