AionFx Cepheus (Cornish CC-1)
apierz
Build Rating
5.00 star(s)
After falling in love with the Chop Shop and making it my main overdrive for the past few weeks, I was “forced” to find another overdrive to pair it with, providing me with a perfect excuse to look through the pcb stack and find something new to build. This one appealed to me because I like my clone of Cornish’s ST-2 a lot and the circuit was different from anything I had built. It’s also a diode clipper, so I figured it would give me a different feel from the Chop Shop’s JFETs.
Build:
It’s a Cornish clone, so @aionfx has packed the PCB full of components, there’s some weird resistor values and I had to use some less-than-ideal sized capacitors, but it all came together well. With five pots I decided to solder the pots to PCB before mounting the board. I hadn’t done it thisaway in a while and promptly soldered the first one to the wrong side. It wasn’t a fun desolder, but that was the only real hiccup. I hardwired the daughter board for buffer always-on.
Sound:
It’s a good overdrive with an active three-band Baxandall EQ so it has a pretty good range of tones. The closest pedal I have is a Mostortion clone. It resolves my two biggest problems with the Mostortion, (too quiet and too compressed), which is great. It sounds good across its range of gain.
Design:
I liked how my ST-2 clone came out, so I did a similar thing with this one. This is my first time using LED lamp shades and I dig the look. The pot spacing on the top row isn’t quite big enough for the normal MXR style knobs, but I found those mini ones which help it match the look of the original.
Overall, I don’t know what would put it ahead of the hundreds of other overdrives you have to choose from, but if you are interested, definitely give it a shot, it won’t disappoint.
Nice build! It looks like you hard-soldered it to buffered bypass... this is the way. :) I really like this drive too, enough that I created my own custom PCB for it. I would never pay $600 for a retail version, but it's worth a DIY build for sure. It does appear to be a somewhat unique circuit - familiar ingredients, but two stages of soft-clipping plus the 3-band Baxandall make it fairly original. To my ears it's fairly EQ neutral by default ("transparent"), so can do the "my amp plus more" thing pretty well too.
You're a madman.
The Mostortion is one of my most disappointing builds. With Buk and so many other session guys gushing over it, I had high hopes and built it with good components and attention to detail. It's fine, I guess. It doesn't sound bad, but it's as boring as taking a dump without reading material.
A+ on the Cornish aesthetic. I started one like that for a Superfuzz pedal I built. I ultimately went in another direction, but here's where I got with it.
Same, I was looking for magic with the Mostortion. I built the PPCB version (Oxide) and when that didn't live up to the hype, I built the AionFX version from their full kit to make double sure all the parts where to spec. Both were just OK. I'm liking the CC-1 a lot, especially as a lower gain overdrive where I might otherwise use a Bluesbreaker style circuit.
