MichaelW
- Build Rating
- 5.00 star(s)
Does anyone remember me saying I was planning to slow down in 2023? Or did I just dream that?
So I've been on a Bjorn Juhl kick lately and have been trying to build all the projects that I could find.
This one is from AionFX and is his "legacy" board before he went down the path of the "125B Only" and the expanded daughterboard.
I've really grown to dislike the breakout board design, if you have a bad footswitch or something, you're basically hosed.
I was really glad to come across the Procyon still available in his earlier 1590B format so I ordered it to continue my quest to build all the BJFE designs I can find.
The Honey Bee has been around for a while and is credited with kicking off the whole "transparent drive" thing. Of course I had no idea it even existed until recently, so for me it's a "new" pedal
Like all of the BJFE designs, this pedal is a pretty unique circuit with some of his hallmark circuit design choices like the "Nature" knob which I'm still trying to wrap my head around what it's actually doing. And his choice of opamps (CA3130), clippers, etc.
It uses 1N4007's as clippers along with red leds.
I made a couple of substitutions based on recommendations from Aion. Some of the component values are from the BearfootFX collaboration era and a couple are Aion's own recommendations to "open up" the pedal a bit more to address the "boxiness" of the original. Since I really have no frame of reference, I decided to follow these recommendations and it definitely does not sound "boxy" to me.
This is a low to medium gain pedal with some quirkiness. Like the drive knob basically tops out around noon on my build after which there is no increase in gain.
But there's that trademark "thick and chewy" breakup that I've found to be common across all the Bjorn Juhl pedals I've built so far.
In testing this pedal, I had it out with first all the other BJFE pedals I've built so far (Skylight Drive-Mad Prof Sky Blue, Resinite Drive-Mad Prof Amber Drive, Splendiferous-Mad Prof Royal Blue) and just for giggles, I threw in the Mojito Deluxe, that has a few BJFE design elements in it.
I also compared it side by side with my all time favorite low gain drive, the Mach 1-Greer Lightspeed.
As a low gain, edge of breakup kind of drive it doesn't have as much low end as the Mach 1, and it also doesn't have that Mach 1 sizzle (that I actually find a bit annoying and usually dial out). While it kind of fits into that same sonic space, it's got it's own thing going on that's not a Timmy or Timmy-derivative.
I keep coming back to the phrase "chewy" even at low gain settings, there's a thickness to the gain that I find absolutely delightful. It's like I can feel it under my fingers when I play through it.
If I set the gain to noon and goose it with the Maleficent Mids it can get into medium gain territory and stacks very well. It also stacks well with some of the other Juhls pedals as a dirty boost. There's some overlap between the Honey Bee and the Royal Blue but they are also different and their own animals.
Really looking forward to a couple more BJFE boards I've got coming from @Robert as well as a Sweet Honey board from @jimilee. The Sweet Honey is a later variant of the Honey Bee and from what I can find out, is supposed to sound a little different. Really looking forward to building that one out! Stay tuned....
This is one of my $3.75....but now $7.00 SmallBear enclosures (dang inflation!)
I had to do a little jiggering to make the board fit in a 1590B and took some thought since it wasn't a PPCB board. So I started by drilling my top jacks and mounting them, then worked from there to make sure I had clearance in order to locate the pots.
Not my favorite way to wire up a footswitch nor my cleanest work. But everything is grounded and the pedal works!
I also subbed an MMBF5457 for the original 2N5952 jfet and used a 1n4004 for the reverse polarity diode. (Original used a 4002, which I didn't have).
After I soldered it in it occurred to me that I could have just used a 1N5817, duh...
I'm usually on autopilot when it comes to drilling enclosures for PPCB projects, so having to think through what I was doing for this one probably took the most brain power heh, but otherwise the build went smooth and went pretty quickly. Fairly low component count. I did socket a couple of the film caps at the recommendation of the build docs, but it sounds so good, I'm leaving it the way it is.
Love how this thing sounds!! Really looking forward to comparing it with @jimilee 's "Honey Bear".
