I have the bass and treble knobs at around 3.00, so pretty high. I forget which one sharpness is! I find it interesting how the bass knob adds so much much more gain in the Lunar Module than it does in the Screwdriver.
I guess my issue is that finding high enough gain Ge trannies is tricky. Recently I swapped the AC127 (hfe 126) I had in my Screwdriver for an MP38 (hfe 64). (I wanted to try the AC127 in a different pedal!)
I really like the sound with the lower gain Ge but it doesn't get very dirty with a Strat. I would be interested in trying a silicon tranny in that position to see what slightly higher gain might sound like - and the extra brightness is easy enough to tame. With a Les Paul or 335 the SD with the MP38 is a great low-gain OD - really, it's amazing. But I would like to try building one with that kind of tone but more gain, and seeing what silicon could do. The LM is all silicon, so it can obviously work. The only reservation I have with the LM is that it still sounds a bit like a fuzz rather than an OD, and it's the clarity of the SD that I really like. The bass strings have a fair bit more definition to them through the SD.
The Screwdriver is close to being exactly what I want. I guess that if the Screwdriver had the gain control of the Hybrid Drive rather than a Fuzz and Pre-drive knobs it would be what I want. Or a Hybrid Drive with the Bass control. So a four-knob pedal. The Hybrid Drive doesn't get fuzzy and lose low-end definition until the gain is quite high - higher than I need. Turning up the Fuzz on a SD does get, well, fuzzy. That's why I use the Pre-gain. But the Pre-gain doesn't go as far as I'd like.
And from there I would like to experiment with silicon transistors in place of the Ge - just because.
