Chuck D. Bones
Circuit Wizard
You don't need to reinstall the caps to make the voltage measurement on R6.
What's the value of R1 & R2?
That soldering on R14 & R15 is horrible. I sure hope that pedal didn't come from Skreddy like that.
Reinstalling ceramic SMD caps is risky. They are easily damaged by the heat of soldering. They don't always fail right away. The thermal stress can cause microcracks, which leads to failure later on. I highly recommend getting new caps and when you solder them, don't touch the tip of the iron to the caps. If you have a hot air pencil, use that.
I'll update my schematic. Looks like a few ref des changed.
It's not surprising that Skreddy had problems with Ge transistors. Good ones are hard to come by and when you build thousands of pedals, warranty returns could be a real problem.
One more thing, can we get photos of the front panel and the serial number? Thnx
