Ambassador - Matchless Hotbox project
Ah, that explains a bit. 250mA is not enough for Ambassador, 500mA is pretty much the minimum required. I typically recommend at least 600mA for dual-tube builds.
I have my eyes peeled out - but did not find that info. I suspected it, but didn‘t find in the docu. Ok ,well than, I am going to get a 600mA thingy. :)
Hi Vigilante, some time later … should the ambassador have line-out level?
It could have it now if you want it. There is a 220k resistor in line with the clean level pot and a 100k in line with the dirty level pot. Jumper those and you'll get a much hotter output.
Btw.: when I switch off the Box on-of for testing, the output is much more less after switching on again. After some hours left alone without further change all is fine again.
(And, while I'm at it - what does the NE555 do? Its a timer, right?)
Thanks y’all! It was a major chore removing the powder coating and getting the bare steel looking the way I wanted it.
I had to use a brass brush on my angle grinder, and then I tried a flap disc, which wasn’t doing what I wanted, so I went with a rotary sander and that did it. I had to be real deliberate with the sanding in order to get it looking uniform.
I knew it wouldn’t be easy, but dang, it took me some time to get it to where I liked it.
Iirc, I had to mount the switch daughter board differently than was recommended in the directions, in order to ensure enough space for using the switch to mount the entire assembly.
Then I used some adhesive zip tie mounts to help hold the board securely.
Thanks so much to Sushi Box for making these available! Next I want to do a Diplomat and a Harlot clone. I’d love to have a DIY Hiwatt or Marshall clone as well.
I used to have a Kingsley Maiden V2, and I miss it. I hope you continue to release awesome DIY PCBs, this was a fun project and it sounds great!
