Thanks y’all! It was a major chore removing the powder coating and getting the bare steel looking the way I wanted it.
I had to use a brass brush on my angle grinder, and then I tried a flap disc, which wasn’t doing what I wanted, so I went with a rotary sander and that did it. I had to be real deliberate with the sanding in order to get it looking uniform.
I knew it wouldn’t be easy, but dang, it took me some time to get it to where I liked it.
Iirc, I had to mount the switch daughter board differently than was recommended in the directions, in order to ensure enough space for using the switch to mount the entire assembly.
Then I used some adhesive zip tie mounts to help hold the board securely.
Thanks so much to Sushi Box for making these available! Next I want to do a Diplomat and a Harlot clone. I’d love to have a DIY Hiwatt or Marshall clone as well.
I used to have a Kingsley Maiden V2, and I miss it. I hope you continue to release awesome DIY PCBs, this was a fun project and it sounds great!
