Another wiring question
Blooze
So I'd like to put a envelope filter and a BMP in the same enclosure with a parallel blend between them. The envelope filter would always be on and then the fuzz could be added. I'm using Madbeans Kraken and Mudbunney boards and a JMK Paralyzer for the parallel blend. Fark me if I can't figure out how to do it correctly.
Here's what I have, but it doesn't seem right to me. The Paralyzer should be the main bypass for the incoming signal, then the fuzz can be turned on and off with the footswitch and blended into the Kraken.
