Locrian99
Good evening all,
I built a strip board layout of the aphrodite that followed the schematic from the PCB. It's working great other than two things. One I feel it sounds a little fizzy, not terrible by any means but theres a little fizz in there I'm hoping this goes away after being boxed. The 2nd thing is when the gain pot is maxed it feedsback, depending on the location of the drive pot it can get pretty bad. Drive pot fully CCW its still annoying and unusable at max gain setting. I thought this might go away after boxing, but another person where I got the layout is reporting the same issue and says his is still doing it after boxing. I'm curious if anyone has built the PCB yet and if they are encountering this same issue. I doubt both he and I made the same error, I haven't traced out the schematic vs. the layout yet. Likely will, but figured I might save myself some time if the issue is the same with the PCB version. The one change I did make from both the schematic and layout is I used a 1044 max and changed c101 to a 10u. But all my voltages appear to be spot on to me.
Thanks!
Thanks!
