Aphrodite Overdrive Custom Pedal
music6000
I was curious to build this as its closely related to the Klon but it has it's own different way of doing it!
If you didn't have a schematic, you would wondering about the Voltage on the Op Amps, the Ground is coming from Pin 5 on the 2 TL072's!
Mods: I used ITT 1N34A Ge Diodes (1N4148's are what is specified).
I used a Fuzz Dog Klon Buffer Footswitch PCB & some carefal planning, used the same hookup as PedalPCB uses.
There are 8 unused pads on the Footswitch PCB, mostly Grounds!
You have to be careful when Soldering the lower 3 pots or you will fry the Box caps!!!
It has a Unique amount of Drive's that you can get from it so it's worth trying out!
The Savage knob is where the Pedal shines giving you some Fatness to the stock Klon style circuit.
Standard In House Printed Graphics!
The design around the switch giving me ZARDOZ vibes but in a good way.
I'm always a klutz when it comes to pots soldered on the component side. I've been doing them on the top recently, but still I get all nervous that they won't seat properly.
Nice work!
