Arachnid Dual Spatialist/Module8
Nate0
Build Rating
5.00 star(s)
I've been enjoying this forum and building pedals for a little over a year. This is my first build report.
I was inspired by the clarity of Bio77's Spatialist's layout, but wanted to build a dual eeprom multi-effect pedal. Thanks also to phi1 for the great pdf for the vero daughter board for the eeproms.
I color coded the waterslide and knobs to make it easier to match the parameters/controls. The 1590bb was a tight fit depth-wise, but worked. I originally planned to put it in a 125b, and ordered pcb mounted pots which I ended up cutting. After I drilled the box I realized that a regular pot wouldn't fit near the power jack, but luckily I had a 9mm pot in the correct value! The guts would have been more elegant if I had planned to use solder lugs before my tayda order.
Anyhow, its great to have inspiring folks such as yourselves making and sharing/posting creative pedals. Thanks!
