I've been scheming for something special ever since I got those knobs.That looks fantastic. The knobs and graphics really work well together.
Rip away, my dude. Happy to send you a file if you need it.that looks incredible! great reminder that I need to rip your aesthetic more often
Totally agree, with so much to choose from and how different the controls are, it's either make it big or carry a crib sheetThat's an awesome panel- totally worth the courageous amount of off-board wiring!
The way you labeled the controls for the different settings is really great- unused settings quickly became mystery settings on my Arachnid build..
Thanks, Gordy! I'm still getting um out every once in awhile.Haven’t seen a Bio build in a while. You certainly haven’t lost your touch, that looks fantastic!!
The slam switch shorts pins 2 and 3 or the dwell control. So, pressing it maxes out the Dwell. It isn't very noticeable on the first few presets but from chamber on you can set the dwell low or in the middle and use the slam switch to engage long ambient sounds. It works really well with the FV-1, it has a nice ramp.Let's talk about that slam switch. What does it do exactly?
Ikr! Those twisted coming off the pots! And the texture of it all. So solidThat layout is absolutely outstanding! It looks so professional and cool. nicely done sir!
Yes, they are awesome. Takes some planning because they fit spline pots. Also, the color on the indicators is dayglo orange. I originally tried having some orange in the graphic but it's not possible to match the knob color with laser print, too dull.Love everything about this!
Are those the "Roland" knobs from Tayda? I was wondering what they look like.
Interesting. I defiantly throw a resistor in there before I send it out. Would you recommend a 1k resistor or lower, say 100 ohm?Man that looks fantastic!
You might want to consider a resistor in series with the Slam switch.
If the Dwell control is fully CCW when you hit the switch it'll short the 3.3V supply to ground.
Alternatively, you could use a normally closed momentary switch to break the connection to lug 1 when it's pressed.
