Arche Boost :: no booost sound light and sound ok but..
alvaro
Hi to all, and thanks for you time, i come again with another pedal its funny when is mading and when sounds.
In this case this precious Arche Boost
The lights goes well, and get sound correct but doesnt apply boost when is switched the spdt. I put images to help
Yes, it's wrong. DD has some eagle eyes.
You can look up the capacitor code.
Basically 10 x where x is a number in this case stands for the number of zeros to follow. So 10 4 is 10 0000 or 100 000 pf or 100nf. The capacitance is 1000 times greater at that point in the circuit than intended and so that might explain your low output.
I would also follow the other advice about cleaning and reflowing solder points
You have a lot of joints that look like they have voids.. like others said looks like you need to reflow all of your joints.. heat them up and flow some more solder on them...
