JohnnyCreepy
Maybe this fits here better than in General questions section. So I have a question for those who have built Arkaim and measured it with DMM. Most of the older threads about this circuit circulate around hefes, but those have saddly no use for my request.
Circuit is tweaked FF with boost. I’m wondering how sfock Arkaim Q1/2 values compare to regular NPN FF values. I’ve read great deal about FF topology, but my skill level isn’t experienced enough for figuring out where to aim with transistor bias adjustment with this particular circuit in topic.
So the questions:
I did differ from suggested build applying low gain&leak germistors for the usual (silicone) blondistors for Q1&2 and a darling(ton) for Q3. Voltages on Q1&2 are okayish, but Q2c is 7.4V or more. I simulated my circuit values in Jack Orman’s Fuzz Face calculator and it revelead transistor currents are 1/10th of typical NPN-Si-FF. With some value play I figured out that reducing Q2e resistor from 10k to 3.6k ohm woukd bring collector voltage down to ~5V and currenfs up, but I’m wondering if there’s insight here about Arkaim circuit and transistor bias before desoldering Q2e resistors
So the questions:
- What have Q1-3 CBE voltages been on your built?
- Have high readings caused some problems?
- Did you adjust voltages changing emitter resistor values?
- Have you had wrong type buzzy note output from softer picking?
