Ashly SC-50 clone
disssa
After successfully rebuilding my version of the Ashly SC-40, I came up with the idea of converting my long-used Ashly SC-50 into a pedal too.
The factory schematics can be found on the Internet. My goal was to fit everything into a 125 BB housing. And everything should be made with conventional through hole components.
So I used the schematics to create a pcb.
Next, assembling the pcb...
Had a couple of these back in the day, they got quite a bit of use a number of things. They were super affordable until TapeOp did an article on them.
Nice. I'm assuming this is vca based. Any unobtanium inside?
Also, curious what steps you took to convert it to instrument level.
Being a massive fan of the SC-50, I had to reach out, in case your pedal is available in any way, shape, or form; be it now or in the future.
Thank you much!
