Awful waffle wiring
Svenson007
Hey guys. This is my first post of many to come. I’ll start off with a dumb question haha. Could anyone tell me if I can use the pedal pcb breakout board to wire the awful waffle? And if so what goes where? I just started using pedalpcb (pcbs) and they are a little different then what I’m used to. Wired up the cream puff with no problem. But the awful waffle wiring looks a little different and the pcb connector pads are not labeled at the bottom on this one.
Thanks!
Reactions: fig
I generally just stick with the build doc if it's anything other than normal to avoid any potential problems
Although you can't see all the switch connections aside from P1 and 2 it looks like you're just disconnecting the drive components from ground in buffered bypass mode so your signal still goes through the circuit without distortion but obviously buffered
