Up until today, I've used the Basic Relay Bypass (latching) on at least 15 pedals without issue. Up until today...
For some reason, the first board + switch that I assembled would switch the LED but not pass signal when turned on. Things I checked:
So I figured that maybe I accidentally fried the IC or relay during assembly (I was admittedly in a hurry) and went about assembling a new one. I was really careful this time, soldering only two pins at a time on the IC and relay. And I was especially diligent about inspecting all the solder joints. I wired it all up and... this one does the exact same thing.
I'm really tempted to just throw in a 3PDT and be done with it, but I'd love to understand what's happening. Any troubleshooting tips to pinpoint what could be wrong?
- All solder joints are solid, and there are no solder bridges.
- All resistors and capacitors are the correct value.
- The 2N3904 and 2N3906 transistors are in the correct place and in the correct orientation.
- The NE555P and relay are in the correct orientation.
