Basic Schematic Question - Shika
cooltapes
Hi guys, I'm a beginner starting out learning circuits, and I'm trying to duplicate the Shika circuit in kicad.
There's three spots with these double circles leading to ground. It looks like the in/out circles are on most schematics, and the SW/GND circles seem to be the footswitch?
What's going on here? Are these different pins on the foot switch or something?
View attachment 122034View attachment 122035
Those are pads for wiring to external input and output jacks, or alternatively to a footswitch.
Technically the switch is omitted for the in/out on the schematic. The in pictured is the circuit in (generally for us coming from the foot switch) but if you omitted the switch it could be read literally as tip = in/out signal and the shaft to ground). Switch (SW) for the ppcb stuff is the LED/CLR portion of the circuit. Some makers leave this off their boards and you're expected to know how to wire a 3PDT switch with the LED block off board. These are included because they are indeed part of the board. They do not affect the sound.
That makes sense. My first build was a Tayda rat pcb and they did not include the LED stuff on the board. So I suppose I could leave that part off then just wire it the same as my tayda build.
