From what I understand about tweeds, you'd be taking a relatively mid-forward circuit (tweed) and turning it into a mid-scooped one. Why? Just build a non-reverb AB763 if you want that tone stack.I also saw I can use the AB763 tone stack in a 5F6A build, could be a good a idea?
I want the breakup of a tweed if I turn Up and if I turn down i want the clean tone of a black :/From what I understand about tweeds, you'd be taking a relatively mid-forward circuit (tweed) and turning it into a mid-scooped one. Why? Just build a non-reverb AB763 if you want that tone stack.
@Feral Feline - That website is a treasure trove! I built a 5E3 head last summer and went back with a few RR mods: Lead Channel and the 3-way NFB mod. Those two alone turned it from a one trick pony into a highly versatile tone machine!
From what I understand, the tweed tone stack (even a TMB) is not equal in execution to an AB763. The Bassman uses a cathode follower tone stack, which (allegedly) has richer harmonics than the plate-driven tone stacks of the BF amps. Also, something something "insertion loss".I want the breakup of a tweed if I turn Up and if I turn down i want the clean tone of a black :/
So maybe is better build AB763 or just changue the tone stack like here.From what I understand, the tweed tone stack (even a TMB) is not equal in execution to an AB763. The Bassman uses a cathode follower tone stack, which (allegedly) has richer harmonics than the plate-driven tone stacks of the BF amps. Also, something something "insertion loss".
Here's the link I'm summarizing from:
Tone stacks 5F6A vs Ab763
Hoffman Amplifiers Tube Amp Forum, Tone stacks 5F6A vs Ab763el34world.com
Have fun, and good luck! I'm currently 8-9 amp builds in.. It's just as addicting as building pedals.So maybe is better build AB763 or just changue the tone stack like here.
thanks
That's what I'm doing with my build ... well, the head part. Haven't entirely mapped out what mods I want. First thing is just to build it mostly stock, then tinker later.@Feral Feline - That website is a treasure trove! I built a 5E3 head last summer and went back with a few RR mods: Lead Channel and the 3-way NFB mod. Those two alone turned it from a one trick pony into a highly versatile tone machine!
