An aside regarding perceived bass response:
Jack Orman swears his MOSFET Boost is good for guitar
or bass. He's done the math, so it must be good on bass I'm sure ... BUT!
The input-cap is 1n and the output-cap is 100n.
Now, take a look at Catalinbread's Sogrado Poblano Picoso, it was marketed as a bass pedal — it's the same circuit, ORMAN's, BUT!...
The input-cap is 10n and the output-cap 220n.
Trust your ears.
Maybe try this on the breadboard: keep the early stages 100n and then for the last stage let a LOT of bass through — try 220n, 470n, even 1µ.
I often see circuits with "choke-points", the circuit's coupling caps throughout are large for lots of bass, then there'll be a choke-point with a much smaller-value cap. For example this
Kit Rae traced circuit has HUGE in/out and couplers then choked after the first stage and is often the case for Muffs with big couplers, choked after the tone-stack:
So why aren't all the bass players raving about this Ram's head? It's got huge caps, even with the choke-points it should deliver the bass freqs.
Look at the diode caps in the clipping section (C6 and C7), they're huge compared to a Russian's 0.047µ, so more of the bass freqs are getting clipped here and mushing out the overall sound. The Russian clips more upper-range freqs with the 47n, leaving more clean bass in the overall signal and I suspect that is why many bass players prefer the Russian version of the circuit.
I'd like to go with 47n caps for the C6 & C7, and see how this Ram's Head would then sound on bass. I'd also like to experiment more with coupling caps in general and by controlling the bass passing through the circuit, not overloading it for the clipping, then let as much bass out as possible AFTER clipping... hmmm basically what HamishR said in post
#19.
Maybe it'd sound better overloading the circuit with bass and getting lots of distortion from that bass overload, then dial it back for the final output so it doesn't overload whatever's next in the chain (another pedal, amp, whatever).
