almondcity
I've built a few with pots for those resistors and it's pretty cool. Makes a huge difference
Sorry, just saw this.Like this at both locations ? Would this wiring work ?
There's a connection between the 680p cap and the diodes that i erased on this picture : On the usual schematics (reply #28), this side of C12 (680p) isn't connected to D3 and D4. I'm not sure how i can connect the 120n cap between them without unsoldering the 680p's leg, but in the other position, with an unsoldered leg, the 680p/diodes connection will be lost ?
Maybe i shouldn't have erased this connection ? No need to unsolder the 680p leg ? Would it work if i keep the 680p/diodes connection as it is ?
Your post #39 was excellent.Findings (or what I like) so far... 180n caps for the coupling caps. 430p for more Civil War.
Tried a few other things and the jury is out.
Has anyone messed with the limiting resistors? Standard on russian/civil war is 10K. Ram's head is 8.5k. The lower you go, the more input into the clipping channels, so the fuzzier you get. I'm wondering if I should even try a 12K just to see if it's more overdrivey.
This is R7 and R12 on the original posted diagram.
I do find that most EQD designs cut out some of the low end. Not sure why they don't just make a bass specific design.I've always had this issue with Muffs so I've been paying attention to this thread with great interest. I've built a dozen plus Muffs and I have yet to hear one that I enjoy the sound of on my bottom two strings. I expected the Boris EQD variant to solve some of this, seeing as they play so downtuned, but found it to be even worse on this front.
I spent some time playing with the muff circuit in LTSpice before realizing I have no idea what exactly the waveforms, frequency response or FFTs would look like to indicate the issues with the bass response that I dislike. As already discussed, the coupling caps play a huge role in the amount of bass that comes through - 220nF and the bass roll off is nearly negligible, but I also am not sure if that is a good thing as far as feeding it into the clipping circuits. One thing I did notice is that the FFT for sine waves in the bass frequency showed a lot more partial subharmonics than I've seen in other circuits, to the point that with some values and pot settings the fundamental is much less prominent of a peak than I would have guessed, or appear in simulations of other circuits that I like with bass and C# standard tuning.
Long way to say I didn't learn much just yet from simulations.
Does anyone have the build docs for Grind Custom's Muff variants? Their stuff IIRC is intended for doom/sludge
I found the build documents for Grind Custom's Ultrastoner - https://www.docdroid.net/KcnBk3s/ultrabuilddocfinal-pdf
The docs have a table of values for other Muff variants too. I still need to look up an audio demo to see if it's better tuned for what I want though.
Thank you so much !I found some time this evening to map out the clipping-diodes & clipping-cap order-swapper
Definitely meI’m calling my version the Gran Verde. I have a parts list on a doc that I’ll share when I get it edited—if anyone is interested!
You’ve invented a new pedal. Market it! I’d love to hear it.I'm finding that if I reduce the value of the clipping caps from 47n to 18n (what I had on hand), a lot more clean bass is passed through and only the top end gets clipped. This sounds good to me... but I have been looking at all of the popular schematics and nobody goes below 47n on the clipping caps. Is there a reason for this that I'm not seeing?
I hope so!You’ve invented a new pedal. Market it! I’d love to hear it.
Bump for Gran Verde doc!I’m calling my version the Gran Verde. I have a parts list on a doc that I’ll share when I get it edited—if anyone is interested!
