Chuck D. Bones
Circuit Wizard
Are you talking about a power supply choke or a choke in the audio signal path?
Exactly what I don't like about the 5E3. You might have just given me the push to finally build one. What value for the 22k dropping resistor next to it? Thanks HamishI like to use a choke in the 5E3s I've built. Tried one on a 5F11 Vibrolux but took it out because it stiffened the sound too much. In a Deluxe it makes things a little clearer and less spongy. I use it to replace the 5K resistor between the first two filter caps.
Cool man. Thanks for sharing.Ha! I don't know, but I use a BF Deluxe style choke. I would be careful with using a SS rectifier unless the Schumachers have a low enough B+. Maybe it's because of where I live - we have 240V 50Hz AC which often varies between 235 and 245V - but I often have issues with the B+ voltages being higher than spec.
The power tranny I last used was the Mercury Magnetics FTDP-E-FS. The E denotes Export I guess, which is what I need. The FS stands for Fat Stack which I am a huge fan of. You can also get Fat Stack output trannies but I find they suck all the character out - they're efficient and they do what they say but I don't care for the tone. But Fat Stack P/T? Yeah, I like 'em for Fender style amps cuz they seem to deliver enough current to produce low end and not fartiness. I don't really know why they work to be honest, but they do IMO.
I just looked at MM's range of 5E3 power trannies - man, they have a lot of options! I like the idea of a P/T with two different B+ windings.
The only reason I use MM is because of the options. One of the best sounding amps I have ever built was a '68 50W plexi clone with Marstran/Heyboer trannies - it sounded so much like a friend's '68 Plexi it was unreal. I don't have access to Lowery organ tansformers!
And I'm not in Chuck's league where tech knowledge is concerned - I'm a photographer, not an electronics guy. But I have built a lot of amps!
