Battery Snap - What Am I Doing Wrong?
joelorigo
I am trying use a battery snap to power a pedal and I am not getting the LED to come on. have tried more than one battery, pedal and snaps. What am I doing wrong? I have a small collection of battery snaps from Godlyke and Voodoo Lab. The reason why I am even trying this is because I am looking into one of these battery power boxes to power my fuzz pedals:
Yes, I have tried this with 4 pedals that were working properly last time I used them, which was recently.
Sorry, I should have specified “when powered by the battery clip alone”. Be aware though, if you are powering an older style fuzz, esp w/ Ge trannys, you might need to use a positive tip plug. Just be sure to match what the manufacturer states
Most pedals will be center-negative. The 9v battery snaps I have that go to an adapter like those are all center-positive. I'd check that with a DMM first. If that's the case you can snip the wires and re-solder it back on with black to red and red to black.
Ah, that makes sense. All the pedals I have tried are center negative. So if that is the issue, if I go try these snaps with my Fulltone 69, it should work, right? And I couldn't use one of the above battery box units with the center positive Fulltone 69, right?
I did try my snaps and they all worked with the 69
I have a PCB partially drawn up for one of those.
Do you mean a simple box to stick batteries in with connections to the jacks (akin to the Dual Effects Loop Switch),
or
something along the lines of: power coming from a PSU into the "battery" box with device(s) like GigRig's Virtual Battery dishing out 9V sim / dying-battery sim etc... ?
@joelorigo — have you tested the pedals with the proper polarity yet (ie centre-negative)?
Hopefully they all had polarity protection when you were testing them with centre-positive; a protection-diode is easy to replace but the rest of the circuit may not be.
Hi, yes everything is working fine. I just bought a used v1 of the Vertex box. It works!
or
The last vero build I did (a DAM 25-17) I used one of those adapters to fire it up for the first time. It took about 20 or 30 seconds for the JRC4558 to start putting off heat and I realized what I'd done.
It's still sitting near my bench to serve as a reminder - the time sunk in to that (I'd had it drilled, mounted and wired - talk about confidence!) and the literal instant it took to kill it was like getting stabbed in the guts - and that's when I turned to PCBs :ROFLMAO:
The good news about hard learned lessons is that they tend to stick with you.
