Best Power Supply
BuddytheReow
Breadboard Baker
Hey Everyone,
Question about power. What is everyone's preferred power source? I know the "ultimate" at least according to Wampler is a 9v battery. I've got a power strip that has my 2 amps (don't worry, I don't use them both simultaneously) and a daisy chain to 4-5 pedals. I'm trying to desperately reduce the amount of plugs needed to have a jam sesh, but I do want nearly all my pedals ready to go at a moment's notice.
Would you guys recommend a few 9v battery snaps, single wall warts, or splurge on a Voodoo labs or Trutone 1SPOT power supply?
Personally I’m not a fan of batteries strictly from an environmental point of view, I’m no tree hugger, but batteries are just nasty bad
For years I used nothing but a simple 1Spot adapter and daisy chain. It worked great, but I occasionally found hum/noise depending on how many pedals were connected and which amp I was using. I since switched to a dedicated power supply (the now discontinued T-Rex Fuel Tank, as it was small enough to fit where I needed it) and everything has been great. Super clean, no issues.
No batteries here. I don't even include the snaps in my builds.
I have been using a one spot for years with no issues. The only time I have issues is if I connect two digital pedals on the same daisy chain. Not all digital pedals, but the line 6 tone core pedals create a lot of noise if two are on the same chain.
After recommendations here, I wound up choosing the true tone CS7. It won’t fit under every pedalboard, but some of the features of this unit are advantageous over other units.
For example, each of the outputs can be either 9 or 12 volts. Each output can put out more mA than is listed on the output, provided you don’t go above the total mA for the unit. You can also get cables that are voltage doublers, or also one that will reduce the 18v output down to 9v.
Their customer service is great too.
I've got a pedal power 2+ and a true tone cs6. Both get the job done
+1 on the Truetone CS6. It's a good compromise between switchable outputs (9/12 and 9/18), # of outputs (6, but I power 9-10 pedals with splitters) and size (fits well under my pedal train metro). I don't really have much digital pedals, but with 2x 500 mA outputs, it can cover some ground.
I picked up a Strymon Zuma a few weeks ago, and it's incredible. Had a PP2+ before, which was great, but to my ears this one is even quieter, and has enough juice to run all the digital stuff too
Would it be possible to get away with a cheaper iso power supply, such as a Donner or Joyo (Amazon)? They're roughly half the price of a Trutone or Voodoo Labs one. I heard a rumor that those aren't isolated...Let's face it, this would be one of the "dullest" guitar oriented purchases ever. I'd rather spend that money and make more pedals ?
I would advise getting a trusted brand, then you're pretty much set. You could probably easily find a used one, I often see them in my parts. I know "utility" purchases aren't sexy, but they are useful in the long run. Or do like me, I just sold 2 pedals (one of them I'll build back) to finance buying a soundcard to more easily record stuff ;)
I waited until I could find a used one at a good price. A used CS7 is typically around 80-90, but if you’re patient you can find them for around 60-70, especially close to the end of the month.
Truetone CS7 user at the moment. My experience is that any of the popular iso bricks (voodoo labs, truetone, etc) are all going to get the job done the best, get the one that meets your power and outlet needs. Many smaller boards can typically run off a daisy chain 1spot with no problems.
