Hi all, first post here. I stumbled across PedalPCB a few weeks ago and was very pleased to see that musikding here in germany has a good selection of PCBs including all the parts. So I ordered a marsh fuzz, because I saw mike hermans demo the BoG a few weeks ago on youtube and very much loved the sound.
It is not my first pedal build but I did my last soldering a few years ago, so I needed a little time to get used to it again. But everything seemed fine, I measured at a few points with my DMM and found a mistake with on of the capacitors in the power cleaning stage so I removed that, because I have no spare part with 220 uF here. But that should not be a problem if my electronic knowledge is not off by a mile.
So I put everything together and turned all knobs to noon (including the internal trimpot) and fired my amp up. Yes! Great sound, as I remembered, but a lot cleaner than I thought. So I turned up the (external) bias pot to around 2 o'clock. Sound completely gone. I thought that's why there is an internal trim pot, so I turned that up and down (even to full and to off) but no sound at all, just cracking. I could not get the pedal to sound normal (whats normal on a fuzz?) again.
Next step was to measure things, i.e. voltages across the board. Vcc was fine on all points and collector voltage at Q1 and Q4 around 6V.
But Q3 was at 1.3V and Q2 was at 2V and both were not changing when I adjusted the internal trim pot. So I replaced the trim pot (as I was thinking that it was broken) with a 1K resistor, because that is the resistance on the collector of Q1 and Q4. I still got those values of around 1 to 2V at Q2 and Q3.
I removed all transistors (I soldered them directly to the PCB) and instead used 4 of those pin-sockets. Inserted 4 new transistors and still, 1-2V on Q2 and Q3.
What am I doing wrong? Or is there nothing wrong and I should look for the fault elsewhere?
Kind regards,
mo
Kind regards,
mo
