anevilspar7an
- Build Rating
- 5.00 star(s)
Back at it again with a 3rd Muzzle build, this time for my rhythm guitarist to replace his ISP Decimator. I did my usual mods to bring the Range switch outside, added a ground lift switch between the key in/thru jacks and the pcb, replaced the TL072 with an OPA2134PA for the I/O, buffers, replaced R7 and R10 with B10K potentiometers to add Shift and Range controls externally, respectively. I also relocated the LED to match the control layout since I used Aion FX's VH Drive Channel template. The enclosure is a 1590BBS Alexandrite from SBP, knobs, switches, a potentiometer, and hardware dress are from LMS, the IC's, jacks, the B10K potentiometers, capacitors (MLCC/Film/Electrolytic), resistors, and diodes are from Mouser. The 560nF cap is a Kemet MLCC from Mouser. Link: 560nF.
