IPv6Freely
I was pretty sure this was the simplest build on PedalPCB, and yet here I am with another failure.
First thing I noticed was that my bypass light was on (though dim) as soon as I applied power. It brightens when the switch is pressed, and then dims again when the effect is turned off. If I kind of push on the LED slightly, it turns off briefly. WHAT.
No sound at all when the effect is engaged. Bypass works fine.
